I went from a ATR 313B to a 204/214 after my 313B wiped 3 cam lobes and a cam bearing. i don't think it was the cams fault(3 valve spring dampers broke at 5000 rpm or so). But I think the 204/214 pulls so much more from any rpm. I would go with a 204/214 over the 313B. Maybe my car just didn't like it and I know others run it without a problem, but mine just seemed to lack any low end, and didn't have much up top either. I don't have track numbers before and after, but with the 204/214 I've now been 12.1 at 112 with only 17 psi and a street chip. There are a lot of good cams out there and most will do the job.
