irrompible
- Aug 13, 2003
Hey guys, me again
I've been narrowing the list of problems I'm having with my TR down, and I'm left with the following...
BLM hangs around 140 - 142 at idle:
This has been an on going problem. I have checked for all possible vac leaks and have found none so I suspect a fuel problem. I have a FP gauge on order so I'll get back to you all with that info. I suppose it's also possible the pump is on it's way out (150,000 miles on pump) how long do they normally last? Weird thing is, if the car is at idle, and I give it a little bit of throttle every now and then (imagine being stuck in very slow moving traffic) then the BLM's will actually drop to 128 and hang there. This is until I get up to speed and come to another stop where they'll be back at ~140.
Knock showing on SM:
This one has me stumped. If it's real knock, then it could certainly be caused by the fuel problem I suspect is causing the high BLM's. But I suspect it is false, and here is why. First of all I'm running 93 oct on a completely stock TR. Now this knock only shows up once in awhile. For example, I could go WOT from a stop light and shut it down at 70 mph all with 0 knock. I could also be cruising down the highway at 65, give it a little gas to pass a car and end up with 6 degress of knock retard. It's because of those two examples that I suspect the knock is false. I'm going to check for broken motor mounts tomorrow and will report back with that info. If I do find they are broken, will a set of stock ones hold me over until I save up for the HRParts mounts?
Sorry for the long post, but I'd really like to get these two issues worked out. If you guys need any additional readings off the SM let me know.
