posted in tranny section but only 1 reply...
jamier
ust question for you all, Just changed my converter to a orange stripe, along with new filter and fluid. took the car out for a drive tonite and it felt bad, The shift from 1-2 felt like it was slipping/ not engaging without letting off and at higher speed around 70mph the rear wheels felt like they were breaking loose. I had no problems with my stock converter no tranny slippage good shifts and my car was going 12 flat at 117mph switched the converter to match the te-60 a bit better then the stock converter, any suggestions on what I should check before running the car hard, not in the mood to do another swap this weekend lol. Do I have to readjust anything or can I rid the shift blues with a shift kit?? I'm open for suggestions help please..the slip feeling is at wot , the car felt like it went into neutral or couldn't find 2nd gear as soon as I let off it found the gear and drove normally also when cruising at higher speed and punching it the car downshifted and pulled hard but something felt wrong the tires felt like they were spinning , might have been the tranny searching for a gear???? I'll try adjusting the cable as soon as I find out hoe to do it???? Also any danger in switching back to the stock converter which worked fine..
