Power antenna info inside
INEEDAGN
Seen Your Member
This is info I gathered using a 1989 mitchell crash book, so I can't guarantee 100% accuracy. I have seen crash books be wrong before on several occasions. This is a list of vehicles that it shows as using the same part number 22048604 power antenna that the TRs use. There are other part numbers that are rumored to work or have some usable parts, but this is for ONLY the 22048604 number. Note: the number 22048605 is for the same applications, but with factory CB radio option. I doubt you run into one and I don't know if they will work.
81-87 regal
81-89 electra/lesabre
83-85 riviera
81-83 eldorado
83-89 impala/caprice
83-88 monte carlo
87-88 cutlass They list the 82-86 cutlass as using a different number (8621) and i have no idea why
82-89 olds 88/98
83-85 toronado
83-86 bonneville
83-87 grand prix
83-89 parisienne/safari
83 firebird (?)
82 camaro (?)
Then I see the number 22048606 (8607 with CB). It appears to be for the earlier years of the same cars, more or less. Don't know anything about it, but judging by the vehicles that use it you may be able to make it work:
82 century
82 monte carlo
80 electra/lesabre
79-80 riviera/eldorado
80 seville
80-82 impala/caprice
81-83 malibu
80-81 olds 88/98
82 omega
82 bonneville
79-80 toronado
82 grand prix
81-87 elcamino/caballero
82 firebird (?)
83 camaro (?)
And THEN I found the number 22048610 (8612 with CB) coming up on other cars of the era so I listed these too. Again, try at your own risk.
83-89 century
83 skyhawk
82-89 deville/fleetwood
84-85 eldorado/seville
82/89 ciera
All the others have rear mount antennas that are very different numbers and I doubt they'll work. Hope this helps someone. Post it in the sticky or modify/discuss as needed.
Bob Koch
After compiling that list I never did find one :)
But I wouldnt ever listen to FM again anyway.
Glad others can benefit.
