SignUp Now!isnt there a differnce on an 86and 87?
Is it possible to swap in a power GN driver seat into my car that doesnt have a power seat? I was thinking maybe the wiring harness is under my seat and it would be plug-n-play?? My T has every option except the power seat....![]()
Brian, I still have that pic you sent me in a file with all my GN stuff...I think I sent you a pic when I sent you the conversion. Man that was awhile ago.
Also factory install the wire is fished inside with the rest of the wires not just behind the kick panel. there are clips that have to be unfolded welded into the body. That is normally how I tell if it is factory installed or installed later.
Brian, I still have that pic you sent me in a file with all my GN stuff...I'd say it goes back approximately 5 years...It was a pic from the car from which the power seat track was removed, showing where to route the power wire under the seat, to the door sill, inside the plastic casing (which houses a lot of other wires), and up under the dash...:smile:
I also remember what you just said about having to route the wire into some flat metal clips (behind the kick pad I believe...) that are welded to the car's body...I did my best to do a "factory" installation, and after the driver's side was done, I decided to do the passenger's side too which also turned out looking factory installed .
Claude. :wink:
I thinking today it was 2002 when I sold you that bud. You should do a nice write up on that. I have done a few passenger sides myself. I go to the 3rd one from the left top connector beside the Driver side. Use the factory orange & black tracer wire. Then hide the splice in the conduit along the base of the windshield. . Down the A-pillar on the driver side & then change to the orange & black tracer wire again. I used #10 stranded orange wire in the conduit. No tracer on it. Orange wire is commonly used in commercial electrical jobs representing a 277 Volt feed.
