Sounds like a FMIC is a waste of money unless i missed something... if its not better at the track i don't see how its better on the street.
If there were FMICs for our cars that offered a lot of flow capability (can support a lot of HP), had low pressure drop (Ideally under 2psi, and no more than 4psi at levels above 1,000hp), and thermal efficiency that was within 20-40degrees of ambient temperature...well, if we had any options like that (or even better than the numbers I proposed) I would say that a FMIC would be a better option than a SLIC, however
at the moment I don't really feel that there are mass produced/NOT-custom cores offered that level of performance or meet that criteria...although if you wait a few months, that crazy company owned by that one asshole..I think they are called "RPS" will be releasing 4 different vertical flow FMIC's for the TR that should offer an affordable alternative to a $3,000 custom FMIC with the same performance levels... and I
think they are also going to release a SLIC liquid to air core, complete with ice box, water pump, water lines, heat exchanger, and turbo/inlet piping...
Well, if you ask Rob, I believe he has gone faster using his Red's SLIC than the FMIC he was using previously...
Most FMIC's that are offered today do not have the same low pressure drop numbers that a PTE SLIC has- side note- not every SLIC that is sold for these cars is very efficient. The PTE SLIC is a good unit, though.
For the very reason of not having many low pressure drop, or thermally efficient FMIC cores for these cars, we decided to make the Bell cores that we designed....they are rated for 1,100hp and 1,600hp, respectively, with .6psi pressure drop while flowing 2,000cfm at 30psi...
