Precision Turbo Saver.....What filter?
Red Regal T
Senior Member
Just ordered the PTE turbo saver. I know it calls for a Baldwin 279 oil filter. What other more common filters can be used?
Thanks for your input. Does AC or purolator have a filter for this application? I don't want to have to send away to get these filters. I could just imagine going to Discount and asking for a Baldwin or Wix filter.
an AC PF 25 can be used with turbo savers. i think the pf 35 can also be used. i forgot which one is bigger.
hth
Hey John..
It uses a filter for a 1966 Pontiac V8 (or there abouts...i know the 66 works)
I usually run the Wix mentioned above on mine.
Just remember that they have to be a non bypass filters. Since you live in Fla.You can get the Wix through Central Auto parts, always in stock. The reason i continue to use the Wix is because when i bought my Saver , thats what it came with.I know i should run the Balwin as i can easily find them in Orlando but i dont drive there often enough.
