Harry Mash
"Turbofan"
- May 3, 2004
When priming the oil pump using a drill motor, do you run the drill motor in a clockwise or counterclockwise direction?
SignUp Now!Originally posted by Black Car
Also you will know when the oil pump starts pumping oil. The drill motor sound will change and you can feel the drill try to twist in your hand.
Gary
Originally posted by tminer
When priming with the drill, is it necessary to fill with oil or vaseline or will it prime anyway?
I coated the pump gears,etc with some oil but did not pack with vaseline and I am not using the oil cooler adapter.
Tom
