- May 24, 2004
Guys the other day my buick went running really bad, checked grounds and such , no luck till I pulled back out on the road and nailed it, ton of black smoke then took off and has been running good again since then. It is running hard but seems a little down on power still. I think the MAF is going south on me but not sure. I have a scanmaster in it but this buick is new to me and I am still learning about it. On a buick that is running GOOD what should all the readings be on a scanmaster? The AF is going to 255 when you nail it and with the hot wire kit it jumps up to 15.4 volts but I am a real newbie on these buicks, thanks in advance Daniel Ray
