Apr 23, 2004 #1 S shawnz Member Joined Apr 20, 2003 Messages 258 Should i be using a lube for my smc kit .Could you use marvel mystery oil or WD 40 thanks John
Apr 23, 2004 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,019 Buy a quart of Klotz lube from Steve. Works great made for methanol too. Lubes more than just the pump. Two capfuls per alky. tankful should last you a year for about $10. Mixes much better than other oils with the alky.
Apr 24, 2004 #3 F fatride Senior Member Joined Aug 13, 2001 Messages 1,947 Where do you buy Klotz from?? Can you get it at a Home Depot??
Apr 24, 2004 #4 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 lube I found Klotz lube @ a Motorcycle shop.
Apr 24, 2004 #5 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,019 I bought 2 quarts over a year ago from Steve at SMC. Not even half done on the first quart yet. I don't go through too many tankfuls in the winter however.
