I'm trying to pump out some fuel tonight using the method I've always used-- hose onto the fitting for my FP gauge that compresses the schrader valve on the rail; alternator power to lead that hot wire plugs into.
Once made, the above connection turns on the pump as normal, but I'm getting literally only a trickle worth of flow through the hose. Not even enough to flow over the fender into the can.
I didn't forget to reconnect connection at the tank, and some fuel is flowing, just a very very small amount. Once I got tired of fooling with it, FP gauge shows normal pressure and car runs fine. What am I missing?
This is the first time I've tried to pump out the fuel with a new double pumper, but I can't see how that would affect it.
thanks,
Scott
thanks,
Scott
