pwr windows
hershillgn
please help!! 86gn both pwr windows work from drivers master switch pass side switch all five wires are hot nothing changes even when you work the switch. been through switches and tried a motor any thoughts???
thanks mike:confused:
The tan and Darkblue/wht. strp. wires should be at ground with the key on and the drivers side switch not activated.
Check the black wire to terminal A of the drivers switch it should be a ground feed to the switch.
