I have an Extender chip and a set of 55's in my car. Problem is it is very rich at idle. Blms are 110-112 at idle. I have tried dropping the fuel pressure from 45 to 43lbs with no change. I have also tried the leaner setting for the mass air meter on the Translator box. No change. I am curious if the spray pattern on the 55's changes with higher fuel pressures. Anyone?
