R.J.S. 5 Point Harness?
Cheeseburger
How did you guys mount the 5th point on the harness?
The other points are straight forward, but the belt that goes between your legs down is what i am asking about.
Thanks in advance! :)
I installed mine using a large eye bolt, one like that used on a engine torque strap but larger.The nut on i its like 5/8 or so. Not huge but beefy. Position the seat in the racing position then the belt. Drill a hole though the floor double nut the eye bolt making sure you have large washers to spread the load. This belt only keeps the belt from riding up from the waist area.
You could also fab up a bracket straight across both front seat bolts.
HTH
Thanks Louie........i was looking at it thinking i would have to drill a hole through the floor, which i am not too keen on.
I will wait till BG and maybe get some ideas on a nice clean install.
Mike. :)
