I can't believe I did this
. I was removing my fan shroud to allow for more room to install a new intercooler shroud for my V4. The old one got crunched on a speed bump. Anyway, I also have an alky kit with the tank mounted on the fan shroud. After removing the bolts on the shroud, it was a tight fit pulling it out. Something on the bottom of the shroud seemed to hang on the bottom area of the radiator on the passenger side. After getting the shroud out, I notice coolant leaking through the lower radiator support. Can't see exactly where it's coming from. Doesn't appear to be from the fins area and I'm almost certain it's not the lower hose. Any ideas what I could have screwed up ?
