Radiator
HellOnWheels
HellOnWheels
Just picked up a new radiator for my GN (87). It has the plastic end tanks, hookup for the trans cooler connections, a drain petcock, an overflow pipe connection, and another "nipple" that looks like a 3/8" line would fit!!??
It's application is for an 88 IROC f-body w/a 350 TPI.
Anyone know what the "nipple" connection is for??
TIA
HOW
I just did that conversion in my car last weekend. Mine had some sort of plug in the middle inbetween the two tranny cooler lines. Mine already had a plug in it. I read on another post... some of the f-body radiators have the plug already.... some don't...... but if it doesn't have the plug..... it will leak out the hole.... gotta get a plug for it.....
Just looked at mine
mine has the plastic plug in it. I guess u should tell the place where u got it from to get another one so u dont have to worry about it. What did u pay for the rad anyway?
I think mine was around $117 + tax or so from Autozone. I told them it was for a '92 Z28 with a 350. When they pulled it up on the computer.... it was the same part number as some of the threads on here said to get....... so I bought it..... 1-3/8 flue ..... the one I got 1 day earlier..... had 1-1/8" flue..... I took it back....... installed the Autozone one..... which came with the plug.......
That nipple is for the heater outlet hose on a F-body. They make plugs that fit over it and are held on with a worm clamp. Watch out! I've blown those plugs out. One was from a bad radiator cap and another time from heat and old age. I'd like to find an end tank with out that nipple so that problem is eliminated.
I plan on adding an oil cooler I bought the other day...... but temporarily.... I have run the hose out using the stock fittings on the hose closest to the battery... and cut the end off at the other fitting..... I then went to Home Depot and bought a 1/2" male pipe to 3/8 pipe bushing... and screwed straight into the oil filter adaptor.... then put a 3/8 male pipe barb fitting for 3/8 hose on it.... slid the oil cooler line over it and put a hose clamp on it.
I would have just bypassed it all together.... by either removing the pancake adaptor... or just plugging both hoses off with 1/2" pipe plugs.... but was unsure if that would work or not.... so I just left it and ran one hose inbetween the two fittings.....
Oil cooler might get installed this weekend.
I am running full synthetic oil now... so I am not as concerned with high oil temps.....
