rail mounted fuel pressure guage
I rail mounted my gauge, I just removed the shcraeder valve and put it on that fitting. I used the small summit liquid filled guage and bought an earl's fitting. I can send you a pic if you want. I should be able to get the pic taken tonight and sent to you in te morning.
Andrew
Sorry this took me an extra day. You'll notice that I am using a Tee on the rail, this is because I have setup a fuel drain over on the fender well. You could do the same thing with a 90 degree flare to pipe fitting. The earls number for this is 982204ERL, then I used the following couplings to mate the male to male parts 991001ERL (pipe thread couple) and 915104ERL (flare coupling). These fittings cost a little bit but I like the way the anodized looks as opposed to brass fittings. I ordered all the parts from summit. If you have any other questions let me know.
Here are the pics:
Andrew
I have one by VDO. Check their site. I don't have a picture but it faces upward and looks clean.
