SignUp Now!Both and at high speed so no need to tap into anything!Originally posted by GrndNatnl
If you get the harness that allows the fans to be plugged into the factory wiring so the ECM controls them, do both fans run? Or just one?
How would I go about wiring the manual (in-car) high speed fan switch, like I have now? (Tapped into the green wire to the relay on the fender). It would be best to run them both at high speed.
Check out these links:Originally posted by TWISTER
Just wondering how everyone is mounting this fan to the radiator supports and where your putting the alky bottle with it when you have a front mount, TIA
Originally posted by Gnx6
http://www.derale.com/electricfanaccess.shtml
I used their kit, Stock No. 16743 to mount mine. Works great. Keeps the fans in nice and close to the rad. I dremeled an edge onto my fans so they fit under the tanks and onto the cores. The edges are rounded on the fan so It won't hurt the core.
