Ramchargers duel fan mounting
turbowannabe
Hey guys,
My car came with the ramchargers duel fan setup when I bought it and seemed to be mounted pretty well, although I could see how it was staying in there as well as it was. It was like it was just wedged inbetween the four top and bottom clips on the radiator. But after I recently just put another motor in my car I can't seem to get it to stay in there well at all. The thing falls out and thanks to my BGC intercooler it stays in there well enough to work as it should. But, it's leaning back against the intercooler and I really want to get it squared away. Any help would be appreciated.
thanks
Dan
I took the bracket from the original fan and cut it in half attatched both pieces to the bottom of the fan and the attatched w/ the same bolts to the bottom. I had to redrill the bracket to match where I wanted it positioned though. At the top I took 2 pieces of flat polished aluminum and drilled them at one end and attatched them where the A/C line is secured above the radiator. they are not attatched to the fan though, they just keep it snug against the radiator. And of course you need to find something to put between the fan and radiator like some small pieces of hard foam so as not to rub a hole in the radiator.;)
If you do a search on this topic you will find a number of links and pictures of some solutions. There have been quite a few different ways people have mounted them.
