V6-Sauce
- Aug 23, 2008
When the car is cold, Once started after idling for about 10-15 minutes temperature gets warm 3/4 of the way on water gauge. The fan does not turn on. I think it's the CTS sensor(coolant temp sensor)it's originial, How do you replace this sensor?. I never did it before. The O2 readings are also very low. I took these Scan reading at idle warmed up. Fuel pressure is holding at 44psi at the regulator.I have a TT chip.
O2-050-very low even after warmed up.
AF-05
L8-34
Bat-13.6-14.0
Int-128
bl-142
Cle-173-temp goes up fast at idle
Ats-84
r-800-900-sometimes alittle lower
Tps-.44
Iac-18
CC-58
Mal-00
smells like fuel
AF-05
L8-34
Bat-13.6-14.0
Int-128
bl-142
Ats-84
Tps-.44
Iac-18
CC-58
Mal-00
smells like fuel
