Recently my car has developed this horrible rattle at idle. I got down to looking for it today, and I discovered that it was one of the engine accessories that was causing the rattle.
I took the belt off and spun each one by hand, and there was no rattle in any of them. I then started the car with none of the accessories on the belt, and there was again, no rattle.
Once I hooked the belt back up, the rattle returned.
The only thing that seemed out of place was the power steering pump. There is a disc in front of the pulley that seems that it should remain stationary. I can turn it by hand, its not easily moved, but it moves. If I tap on that disc, I get a slight rattle, but not bad enough to do what it does while running.
Oh, and the rattle seems to go away past about 1000 rpms.
Any thoughts?
Any thoughts?
