Razors alky /wiring issue
NOKA72
Hey guys. Didn’t get a chance to look at it. Have to take the boy to scouts. So this afternoon. Car is running rough every so often at idle. So I take a quick look and shake harnesses around. And when I shake the tps harness that goes to the map. I hear the pump kick on and of course is dumping fuel. Been a long time since the install I have to locate the instructions. But the jumper that plugs into tps that was what. Power ground and what exactly. Thanks. VINNY
What’s up guys. Went down to check it. I found the tps connector from the main harness to the kits jumper had pulled apart. Im going to have to repin the whole connector. Hopefully that’s it. We’ll see. VINNY
