Ready to upgrade fuel system
gnkid1987
i am ready to upgrade my fuel pump and injectors i have an ajustable fuel pressure regulator onthe car i was just wondering what lb injectors to get the car is moastly stock but i am eventually going to change downpipe, turbo (TA-49), and a few other things i was thinking 36lb from poston entiprises i just wanna make sure i buy the correct ones before i blow 250 on them
You don't necessarily need injectors until you upgrade that stock turbo. Go ahead and upgrade the fuel system with a fuel pump hotwire kit and a good in tank pump (XP or Walbro) as well as a volt booster system before you start upgrading. Don't waste your money on 36#ers. If you plan on going with the TA-49, I would recommend 43# (009) injectors. The fuel pump upgrades would be a good idea right now as the stock system and wiring was marginal at best when new. Good luck;)
