rear axle rebuild
fast NY Six
I was in the process of changing the diff lube and found a chipped ring gear tooth. I've ordered the gears, does anyone know the bearing part numbers for the pinion and carrier? Or who sells a quality rebuild kit?. Timkin lists bearings for the 7.5 but not much for the 8.5. thanks
oh sorry i made a mistake on that ratech kit that 3031K is for eaton posi (larger ID carrier bearings ) but kit includes axle bearings and seals which you should also change and be sure to check axles for any brinneling from debris and might as well check the tubes for straightness
OK thanks. I ordered the master kit. Do I need the case spreader tool or can i get by without it?
Case spreader is not needed. National or Timken bearings are fine
