Im trying to find out which brake line is to the rear brakes comming from the master cylinder on my 87 MonteCarlo, is it the thinner line closer to the fire wall or the thicker line further from the fire wall, I did the Wilwood manual brake kit ,and the Wilwood residual valve is only made for the thinner line, first I was told the thicker brake line further from the firewall is for the front brakes because the front brakes do all the work so they use a thicker line, then I was just told the thicker line is for the rear, (after I already cut my brake lines and flared them for the Wilwood residual valve)...I thought I was done, am I done? or do I need to re-do them?...I would like to thank Wilwood for not posting up any neccicary info on there G-body swap kit, VERY PERFESSIONAL!!!..thanks Wilwood
