rear lower controll arms
phil conrad
On my GN the rear end squeaks. It also "groans". I have the large ATR sway bar. I have heard this is a common problem. Is there a way to fix this ? I am thinking of replacing the bushings and either boxing the rear arms or replacing them .
If replacing the controll arms is there an aftermarket set ? If so where is a good place to buy ?
What ever you decide to buy, make sure you get spherical bearings where the arm attaches to the frame. This will help with the inherent binding in the four link.:)
