here is my combo
1. g80 rear with moser axles and girdle
2. h&r rear sway bar
3 h&r 1/4 inch longer lower arms
4. boxed upper
5. variable rate springs
6. two empty airbags with spacers
7. comp eng. drag shocks
8. front drag springs and 90/10 shocks
9. no front swaybar
here is my situation
the rear of my car will barely move up and down. It is very stiff over bumps. i thought it was the drags shocks, so i replaced them with some old tired el cheapos.
SAME PROBLEM
but... when i looked at the coil spring while it was on the rack, all the tightly wound coils on the spring were touching.
should i replace the springs with some stock replacements?
some "experts" say the rear end should be stiff during a launch, others say it should squat.
i cant leave at zero psi without lighting up the warmed up drag radials.
thanks
surej
4. boxed upper
9. no front swaybar
SAME PROBLEM
thanks
surej
