i'm wanting to rebuild too but i need some thoughts from anyone who has used any of these kits out there. first off i'm wanting to go into the low 12's high 11's eventually so i dont' NEED a performance built motor but it would probably pay off to do what i can while i'm in the engine.
summit sells a kit for $230 or $320, its just oil pump, pistons and bearings and gaskets.
one of the vendors here, i forget who it was sells one with most internal parts, everythign summit has plus valve springs, timming chains, rocker arms, push rods, "performance" cam (don't know what kind that is)
while i'm at it i plan on pulling the engine and having it bored .030 over maybe have it blanced depending on how money is looking. I'll also clean up the heads and maybe bore it for bigger valves (does that help much in our cars?)
are there any other good kits out there that are a little less money or better buys?
also whats the difference between cast hypereutectic (thats that?) and forged as for as what would you would need goes?
thanks in advance!
