Recommended Digital gauges
99ssconv
Banned
I am looking into a digital fuel pressure and vac/boost gauge, I would like to get the same brand and style so they match. Looking at putting them in a dual pillar pod. Cyberdyne has them but the boost gauge only goes to 23 psi. Any thoughts, I am running 99% stock set up, for shows mostly, but would like the 30 psi gauge for future possibilities. Anyone seen these in person, do they look cheap????
Nordskog Boost Gauge
I have the Nordskog boost gauge M9019 that shows 5-40 PSI and it works pretty good for me. I have a digital dash and all green Nordskorg gauges for Boost, RPM, Coolant Temp and Oil Pressure and haben't had any problems with them. The only comment on the Boost gauge is you have to sustain boost for a couple of seconds to use the push button high boost recall feature. In other words if you mommentarily go up to 10 PSI of boost, the gauge will show boost go up and down to 10 PSI, but if hit recall button it will not show any high boost. That will only show when you sustain that boost level for a second or two.
http://www.nordskogperformance.net/products/auto/streetdigital/page6.htm
Dakota Digital is another good option, for high quality, if you are not on a tight budget.
