I just pulled mine and it was very easy. First start taking off all the accesories like the A/C pump, PS pump, alternator, intercooler, turbo, headers, DP, basically everything exept the front timing case. I took off my upper and lower intake before i pulled it and hooked the hoist into the head bolts. LABEL EVERYTHING!!!!. To dissconnect the tranny you can get to the top two bolts with a regular i think it was 9/16" wrench after removing the coils. The rest can be reached under the car with an extension about 3-4 feet long with a swivel or thoes extensions that have like a few degree of deflection and put a few together. The bottom ones are self explainitory. Im trying to think what else is trickey...... oh! Its easier to pull the motor out with the hood shocks disconnected and someone or something holding the hood all the way up. Make sure all your grounds are off. Theres a few on the back of the intake and i had one on the front head. Label everything and make sure your battery is dissconected and just to be carefull the fuse on the FP. Hope this helps a little.
