Silver Fox
- Apr 17, 2003
I finally got my driver's side header off to reweld it. I have a friend who is a professional welder (for aircraft) who is going to take care of it Monday (12 June) for me. I think he is going to TIG weld with stainless steel rod.
Does anyone who has done this have any good tips/advice so I will not have to do this again in a year or two?
I am also wondering about the factory heat shield on the header. Should I just leave this off after we weld it? I do not believe I need to put this back on after taking it off to reweld the crack.
Also, does the header have to be bolted to something to keep it from warping during the welding process?
And as far as reinstalling the header, I have been advised by a fellow board member to just use some copper based RTV on the header flange (where it bolts up to the head), and it should seal up okay.
Thanks in advance for the help.
Rob
Rob
