Right front is 1 1/2 lower then the left ??
SS/GN
2,181
302
83
55
As mentioned, check springs and ride height. Look at ALL suspension and body bushings. Loosen suspension and go for a drive around the block. Re check and snug up. I have found many a car with the suspension binding up.
bpman1234
1,828
104
63
south florida
Yes did the measuring driver is like 1 " higher from back off the front tire chassis Where you would Jack it up. Then measured The fender at the top of the ark center molding wheel well.its more like 1 1/2"..
Pronto
Chaos is a ladder.
Dec 9, 2002
12,017
1,186
113
Nashua, NH
So lets back up. Did you just notice this or has it been like this for a while? Did you do front suspension work and notice this? Are the body bushings new or old?
  • Like
Reactions: No disintegrations
bpman1234
1,828
104
63
south florida
Old body bushings never replaced been like that for a minute ..just redone my wheel bearings and seals and decide to look at it at the same time .
Pronto
Chaos is a ladder.
Dec 9, 2002
12,017
1,186
113
Nashua, NH
With the weight of a driver I bet the measurements at the chassis would be equal. Probably time for body bushings. ..
DeltaBravo
Retired U.S. Army/Navy
Jun 14, 2014
376
39
28
Long Beach, CA
No disintegrations
929
129
43
42
I also think body bushings are most likely culprit. When measuring something like this it may help to move the car to differ areas of pavement to make sure you're not fighting uneven ground.
