I have a block at the shop getting Decked,tanked with new freeze out plugs and cam bearings..Also the crank is going .010 under due to a wiped cam...I am not sure which Bearings to go with....I also would like to Know what the diffrence is between the Total seal Top ring set and the second Ring set...The car will be a weekend cruiser,And will see the track often enough....The combo: GN1's..T&D 1.65 RR's...CPT 65....comp 212/212...50's...Precision Front mount...62/65 Tb...Mease Plenum...3"TH Downpipe.
The cam is not a definate yet,I am still debating on which to go with...Just not sure what bearing to use,And havent heard much on the total seals yet...
I need to order the Rings and Bearings ASAP...So the best place to get the stuff,Or part #'s would be a big help also...
Any help/Info is appreciated
Thanks,Shawn
Thanks,Shawn
