RJC pcv valve
ikle
I am looking for a pcv that will give me no issues and was thinking about purchasing this one from RJC Racing. I know they make great products and was wondering if this would be a great upgrade. Thanks,Kyle.
I put the RJC check valve in line with the stock style PCV valve and it helped reduce oil blowing out the breather.
The RJC Check valve is meant to be used as a replacement of the stock PCV valve.
Just throw out the stock PCV vlave, as they are useless. The Check valve is a quality piece.
Adrian
This has been discussed at length. Some people have problems with vacuum being metered properly with just the RJC valve and this is why some use it in line with a stock pcv. It does work very well for keeping boost out of the crankcase. Keep an eye on your BLs if you use it alone and if they are fine or don't change from normal, you are probably fine.
