Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
What do you think about a timing cover that uses a crank driven front wheel drive oil pump? I have taken the time to design one myself and it works like a charm. I know this would require the harmonic balancer to be shortened since the oil pump is driven off of the lower timing gear. The stock thrust button will not work either so an adjustable solid thrust button would be required. I found that out when I seen my cam walking forward while cranking the engine while it was on the engine stand.
