Roll a lip?
Buick Beginner
Where is my $$$ going?
It seems my rear end is un-even and my 275-60 DRs are going to scrub a bit on one of the rear wheel wells. So what's the best way to roll the lip? It seems simple enough but I figured I'd check with the experts first. - BB:D
Lots of ways to roll it...best way is a good ole fashioned base ball bat. Jack the car up, insert the bat and ease the car down a bit until it puts a little pressure on the bat against the 1/4 panel. Slowly spin the wheel/roll the bat and push down on the bat while rotating it along the 1/4. The more pressure you put on it, the more you will roll the lip. Pray there is no bondo along the 1/4 lip (can you say crack!)
I personally trimmed mine with an air saw.
The bat works great
I have used that trick personally many times. If the car isn't heavy enough, you may may need to enlist the help of a hefty friend or two to sit on the edge of the trunk, (not on the lid, but under the open lid, ;) ). Wooden bats work best, but pipe of about the same size will do the job too, in a pinch.
