I need some help. I cant get my 87 TR to idle. I've looked at the usual culprits and Im stumped. Car has recently installed MSD 50's. Car ran fine for several weeks after new injector and chip combo. Car has very rough idle and stumble. At idle its running rich enough to throw code 44. Can't get IAC count below 65 to 70.
Readjusted IAC, Replaced IAC.
TPS set. FP set at 42. Tried 38 to 45 lbs no difference.
Swapped MAF.
Replaced PCV valve.
Unable to locate any vacuum leaks. Tried carb cleaner and propane.
Input appreciated.
John
Swapped MAF.
Replaced PCV valve.
Input appreciated.
John
