Rough idle, slight stumble
kenny
No turbo, no care.
IAC is about 25 at idle. For some reason it keeps fluctuating? (anywhere from 20-35)
TPS is at .44
The stumble is when you slightly hit the gas, stumbles, then it's fine.
Rough idle is just that, rough. Idles from 650-725... :confused:
What chip? Make sure you have atleased one screen in MAF, try putting both screens in if you took one out. Everytime this happens to my car it's because I f%$#@! with the MAF. Some chips don't like when you take one out. Good luck!:)
Not sure of the chip. Just bought the car a couple days ago. I'll have to check to see if there are one or two screens in the MAF.
Also need to change the fuel filter.
slight stumble as you ease into the throttle?
does it do this everytime?
i noticed once i changed over to the msd 50's my silver car does the same thing-
but the car has no maf screens and a reds 107 chip all the time-
Ya does it all the time, it's like a slight hesitation. Kind of annoying, but it hasn't stalled or anything.
