This is for the high performance guys. I just got my T-type on the road after three years of restoration. I did alot of work to the engine, CNC heads, cam, T63E, ATR front mount, etc. Hear is the problem, if I boost the engine the temp spikes, HARD. I drove it for seven miles no boost temp went to 190. As soon as I boosted the temp climbed and climbed. I have a 160 stat, flow cooler coolant pump, and am running Evans NPG for coolant. I already removed the heads thinking head gaskets, they were ok. I also tried a shorter belt ( maybe slipping) no better. Help!! Thanks in advance.
