Running wire through firewall on passenger side?
V6UnderPressure
The Artist FKA Scott4DMny
May 27, 2001
2,489
26
48
41
New Lenox, IL
I am mounting my Innovative boost controller and T-Plus on the back of the glove compartment. I want to run the wires on the passenger side through the firewall (to keep everything neat). Where around the passenger side could I drill a hole for a grommet that is easy to get to and safe?
Scott
REDS HOT AIR
Buick Tweaker
May 24, 2001
3,123
1
0
45
newport news va.
Visit site
theres a big rubber grommet at bottom corner of the heat/ac box that the wires for the blower motor and stuff go thru.
you can find it from inside the car not far from where the ecm harness goes thru
there is plenty of room in the heat/a/c grommet to drill a hole thru it to feed your wire and not have to drill the firewall
on drivers side I go thru the grommet for the cruise control harness
fireberd350
834
0
16
35
Drexel Hill, PA
picasaweb.google.com
super old thread, but this is the only info search returned for me....
anyways I was looking for some time tonight and don't recall seeing a large grommet with plenty of room to drill into. I only need to run a small tube for mechanical oil pressure. I'd was gonna run a water temp too but the hole will need to be like 1/2" or larger. Not worth the hassle.
Any ideas for getting the tube through the passenger side firewall would be great. Thanks.
V6UnderPressure
May 27, 2001
2,489
26
48
41
New Lenox, IL
When my car was under construction (and still is), I removed the plastic inner fender well. Its not easy, you need a 1/4" extension with swivel & 10mm socket to get the bolts near the AC box. But it is much much easier to do all this wiring with it removed. Otherwise, you can undo the bolts underneath and try to wedge in there. But personally, I like alot of extra room.
TR Custom Parts
Mark Hueffman - Owner
May 25, 2001
9,499
334
83
62
North Haven CT
www.buickgn.com
When I did my wideband install I pulled back the carpet on the pass side and drilled a hole up high on the floorboard, see pic. My wideband sensor mounts towards the end of the downpipe and allowed me to mount the LC1 controller behind the glovebox. Obviously, I put a grommet on the hole after this pic was taken and I also run my fuel pressure transducer wires thru here as well as my future installation of my EGT wires. The grommet where the speedo cable goes was pretty much loaded up with enough wires already.
TURBO 6
Beer Snob
Staff member
May 24, 2001
1,765
42
48
43
Louisiana
No need to drill. Locate the grommet under the dash on the passenger side. You'll see it in the very top right under the dash. There's a "plug" with vac lines running through it, pull the plug out engough to stick a coat hanger through. Run a coat hanger through the hole, when it comes out, attach your wires to the hanger, then pull it back through. Done.
fireberd350
834
0
16
35
Drexel Hill, PA
Thanks for the pic. If all else fails this may be the route I take.
No need to drill. Locate the grommet under the dash on the passenger side. You'll see it in the very top right under the dash. .
I will check again tonight. I don't recall seeing any vac lines through a grommet. All I remember seeing is 2 holes for a bunch of wires.
TR Custom Parts
May 25, 2001
9,499
334
83
62
North Haven CT
www.buickgn.com
I ran my hole there for an easy install of the wideband without have to extend the harness. No biggie drilling a hole. With all the other things we do to these cars, what's one hole? The grommet discussed on the pass side is there but hard to get from what I saw.
ryan george
312
10
18
Akron
I did the same as Mark. Works great. You'll need quite a hole in that existing grommet to fit the sensor thru. It's not the size of a wire...:confused:
fireberd350
834
0
16
35
Drexel Hill, PA
The oil line is about the size of a 14 gauge wire. It's just a nylon tube. I will try to avoid drilling the floorboard if possible. If I knew I was gonna drill a hole there I would have ran the Alky wires there (PAC mounted behind glove box), doh. Oh well.
87geeinn
1,281
49
48
I've drilled a total of five different holes in various parts of my firewall to route wires. Don't be scared to drill. :D
Now, lemme see how many zip-ties I've used on the car. :tongue:
machinegun
1,402
9
38
Akron, OH
Visit site
Just recommendation, do not use the nylon tubing. Pay the extra money and get a copper line kit if running a mechanical. To be honest with the accuray of the electric gauges out there, I would recommend that if for nothing else but yout temp gauge
Feeding up through the passenger side works excllent and gives you a nice clean look.
I prefer to do the least amount of cutting or drilling on a car that mihgt go back to stock sometime.
  • Like
Reactions: STGMAN
salvageV6
Daily Driver
May 25, 2001
14,860
335
83
63
Connecticut
" I've drilled a total of five different holes in various parts of my firewall to route wires. Don't be scared to drill.
Now, lemme see how many zip-ties I've used on the car. "
Yep. :)
I used a stepped Unibit on the GN worked great, used a Greenlee punch years ago on the WE4.
Rtv'd a plastic edge on it although a few layers of properly placed Scotch 33+ tape will also work well after filing the edges smooth.
Don't forget a spare pull wire put in place for the next install. :)
Drill it and fill it. :p
fireberd350
834
0
16
35
Drexel Hill, PA
I was able to use the existing grommet. There were vac lines but I didn't recognize them b/c they are colored like wires.
For future reference theres 2 holes on the pass side near the ECM. The top one has a yellow plug in the middle of it. This is the one I drilled through because the grommet had plenty of extra space around it.
TURBO 6
Beer Snob
Staff member
May 24, 2001
1,765
42
48
43
Louisiana
Or you could have pulled the yellow plug out of the grommet. It's really hard to get it out, but it'll come out.
TireFryer
Behold, The Power of "V6"
Dec 21, 2001
219
15
18
MICHIGAN
Old thread but where does this grommet come in the engine bay? Behind the fender or somewhere accessible?
Trying to avoid using DS grommet to bring wires all the way back to the PS.
Top Bottom
