S10 and a GN
Goat
I heart Boost and DRs...
Dec 2, 2009
1,022
9
38
33
Bossier City, La sittings in the shop!
Im taken my 99 S10 and putting a GN motor into it after a turn of events happen...I wanted to know if this has been done and if the GN 3.8 will clear my hood and so fourth...Any help is needed as for this is my time for a project on this level..
S10xGN
RETIRED!
May 26, 2001
2,107
75
48
66
Port Neches, TX
Imma need some help with mine cause i want to do a 5 speed but Im airbagged and all will you please help me here and also can I run a sticker that you have on your truck?
Wow, your ride is quite a bit different... Did you check my web? The whole build is there for all to see. When you get into a specific problem, let me know and I'll see if I can help.
I still have the sticker file, and can make them for $15.00 each plus postage...
dr_frankenstein
Mad Scientist
Mar 17, 2008
4,662
135
63
Lost Causes, NM
sounds as if this has become alllll tooo popular all of a sudden.
if this is your first time.... its gonna be fun. just wait till the heater box to exhaust comes to play.
but I agree.... might as well go with the 86/87 intercooled motor to be worth th trouble.
and I imagine you need to know what parts to keep the stick you need too right?
which 5 speed are you running now? the stock GM T5?
A.j.
"Turbo-T"
V6 on steroids
Jan 10, 2007
5,809
16
38
Missouri
I may be wrong but I don't think they used T-5's in S-10's after 1993: I'm almost positive the T-5 was reserved for 2.5 and 2.8 liter engines, both which were not used after 1993. Most likely if it's the stock tranny it's a NV3500, but neither it nor the T-5 would probably live long behind a turbo 6 Buick.
Top Bottom
