TexasT
Texas, Where are you from
- Sep 10, 2002
I have the no charge problem. I pulled the dash apart. Light bulb is continuous. The resistor in the twist in bulb holder shows resistance. I put the bulb in the holder with it removed from the dash and is doesn't have continuity across the two places it touches the back of the dash. I couldn't see how to pull the rear cover off of the bulb holder so I thought I'd ask before I break it. Am I wrong to think it should show resistance across those dash prong? TIA
I can take some pix if it would help dianose. Also I did a search and lots of reading. Might just buy that jump harness from caspers.
Anyone have some thoughts?
