Scanmaster numbers
86 GN DDR
Here are my Scanmaster numbers
AF 6
LB 37
BAT 13.7
INT 128
BLM 109
MPH 00
CLT 164
ATS 91
RPM 950
TPS 40
IAC 00
CC 196
MAL 00
O2MV 460
Mods
Aeromotive FP/HOTWIRE KIT
LS1 3.5 MAF
KN COLD AIR INTAKE
TR6
IRIDIUM PLUS
GN1 PERFORMANCE RADIATOR
TSAT 160
Aftermarket chip (Unknown) Gonna investigate
Blue top injectors
First time I posted any numbers after I placed these mods.
Any tips or advice appreciated. .Just looking to see if I'm headed in the right direction
Your iac being 0 means your ECM is trying to close the iac air passage all the way to lower your idle. With the idle at 900 and iac at 0 means there is unmetered air coming from somewhere.
Disclaimer** I am not a guru and could be totally wrong. I just did a lot of reading when I had similiar situation. Good luck
But then again your block learn is low indicating a rich condition which I think rules out a vacuum leak.
These cars are so damn confusing. Haha good luck.
I think the blue top is 36 lb. maybe pull your chip and make sure it's made for them
New Scanmaster readings after adjusting TPS sensor..I set it at .38 and adjusted IAC..I went for a drive and these were my numbers. I was cruising at 60 MPH
O2MV 605
AF 40
LV8 85
BAT 13.3
INT 125
BLM 138-141
MPH 60
CLT 162
ATS 57
RPM 2450
TPS .94
IAC 42
CC 241
MAL 00
I've been told that the TR6 will go into a lean cruise mode. I don't have a wideband O2 setup but I'm assuming that since by BLMs are on the high end of normal that the TR6 would be the cause. Just a theory. Any other advice?
what would be perfect numbers for scan tool ?on stock 86 gn
The only perfect number worth striving for is 0 knock. All other numbers should fall into an acceptable range (see attached). You'll drive yourself nuts if you get hung up on hitting a certain number.
  • ScanmasterDefinitions-2.pdf
