Lee O. Thompson
- Oct 12, 2014
I would like to know what people are using for sealing rings on the center support (GN). Factory steel or 400 teflon and why you prefer what you use. Thanks All replies are welcome.
Need a shrinking tool for the teflonDo you have a link to the 1/8" servon compressor ring?
Haven't tried the Teflon on the center support. The iron looked good and the mating surface didn't catch a finger nail so mine has iron.
I'll look up the A470 Chrysler and get some to have on hand for the next build.
BUT...…….Here’s a thread I started on the subject a couple years back. Hope it helps
Direct drum rings
Short version: had to hone some minor ring wear out of an otherwise cherry drum (from a low mile trans) and it measures about .001-.0015 out of round with a bore gauge. Didn't measure the actual dimension (though I can) but it wasn't a lot of honing. I'm sure it will physically function fine...turbobuick.com
BUT...…….
What did it measure top to bottom within the bore?
In other words what is the "taper" in the bore front to back?
Sometimes the ring bore is different among the 3 rings......
Seen it....
WE4
Still using Teflon. Husek says not too but I have no issues. You can also scarf cut them to seal an irregular surface...I don't do that .
And I don't.....I wouldn’t scarf cut the commonly used 4L80 ring.
I learned that from you for sure. I don't have many 200's out there with the power level of engines that come out of your shop. Now you have your plate, someone copied it, then I copied it as well. So we have the direct thing well in check I think. i know you and I have had some pretty good tech chats over the years....learned a bunch still learning too.Direct clutch setup and pressure plate is just as important. The only pressure plates I’ve seen that were not purpose made for high pressures that seemed to work ok are the assembly line ones. The replacement ones availble are junk. I even tested a cold rolled steel pressure plate that was laser cut and it didn’t warp like the commonly found ones.
I just checked out that part number...interesting maybe something to look into.The thing I’ve taken away from all these conversations about rings is that the solid Teflons don’t handle being overheated. If we look at the source application for the rings, the 4L80e, they came with solid Teflon and the aftermarket has stepped in with “better” alternatives, namely a Vespel plastic ring and the transgo 4L80e-htrk high temperature ring kit which is a scarf cut ring with an expander under it. People like Steve will probably never have a problem with solid Teflon because he has pretty good control over where his builds end up and ensures adequate cooling etc. People like Dave and Lonnie are shipping these things all over the country to people who’ve never even seen a turbo Buick and are putting them in street rods and other vehicles and the customer’s knowledge of trans cooling is hit or miss at best. They can’t run solid Teflons because if it gets hot once the directs are done. In that situation anything is better than solid Teflon especially since the engine in front of it is maybe 350-400 hp at most.
I’m also nearly certain that one or more persons has figured out a better solution than all the publicly known options and has (rightfully) chosen to remain tight lipped about their findings. Even Dave’s availability of an oversized iron ring is rightfully kept to himself as to what it’s normally used in. Most hobbyists don’t have the ability to machine the bore properly anyway.
I do love these discussions though
