service parts sticker
the wrath
how do you remove these stickers if you are going to replace your trunk i dont want to damage it
You mean the label with all the option codes? If so - cover it with a piece of non yellowing clear tape or preferably glue backed acetate, wider and longer than the label. Seal it down tight. This will now be a permanent part of the label and help protect the info and keep it in one piece. Trim the edges down to the label size. Spray a little windex on the edge of the label and slowly scrape a single edge razor blade behind it. A blade holder works well too. As you go add more windex and be careful and work slow. I have used this method on various labels. Good Luck! :D
