OneLethal87GN
R.I.P. Lethal GN
- May 26, 2001
After a very long engine rebuild I finally got the car back a few months ago. It's been sitting ever since due to my taking the time to get it looking decent again. Before the rebuild I had the problem of low pressure showing on my K-B hood-mounted gauge. It shows high 20s at idle when cold. When I turn the K-B boost-a-pump up all the way up it goes to low 40s. At high 20s the car stumbles and cuts off. It doesn't with the low 40s. When I go to set the pressure do I let the car reach operating temps first or just do it cold? I need to set the IAC too and know it needs to be warm when setting but wasn't sure about the fuel pressure. I plan on putting it back on the raod soon. I just want some new tires and rims first due to the car sitting in the guys front yard for 9 months and the rims rusting due to wet grass that sat in the rims after he cut it and it rained. Some white crap also showed up on the spinners and keeps coming back every time I clean it off.
Also, I still have the 009s but with alot more airflow than before so should low boost and high timing be the way to go? I have both a street and a race chip but will get a Turbotweak chip burnt when I get the car on the road again.
