Sheet Metal Trans Pan ?
Discussion in 'Transmission Talk' started by jmendlik, Oct 12, 2017 at 8:28 AM.
  1. jmendlik
    jmendlik
    Expand Collapse
    Oct 1, 2001
    594
    22
    Online
    Anyone ever seen this type of filter used with a custom Aluminum pan? Is this is one of PTS Extreme bottom feeder set-up?
    I may purchase this pan set-up for my 200-4R trans.
    Where can a new one ( Filter) be purchased ?? Got a part number on this filter?
    JM
    #1 jmendlik, Oct 12, 2017 at 8:28 AM
  2. INEEDAGN
    INEEDAGN
    Expand Collapse
    Seen Your Member
    Feb 28, 2003
    3,570
    265
    Offline
    Yes and that's a mopar 727 filter.
  3. Boost231
    Boost231
    Expand Collapse
    What's An Intercooler
    Staff Member
    May 26, 2001
    13,847
    432
    Offline
    Yes, same setup I run
  4. turbo nasty
    turbo nasty
    Expand Collapse
    Goat Milk Racing
    Jul 19, 2001
    7,842
    272
    Offline
    Looks like a old PTS setup
  5. jmendlik
    jmendlik
    Expand Collapse
    Oct 1, 2001
    594
    22
    Online
    is this worth $200...on a flat surface it does rock a little so it needs to be worked on to be flat/ture
  6. INEEDAGN
    INEEDAGN
    Expand Collapse
    Seen Your Member
    Feb 28, 2003
    3,570
    265
    Offline
    I'd say it is. You have to watch your ground clearance with it but otherwise it should be fine. The only thing that has to be flat is the gasket surface.
  7. Boost231
    Boost231
    Expand Collapse
    Staff Member
    May 26, 2001
    13,847
    432
    Offline
    Never had issues with mine omas for ground clearance.
    Imop that looks similar to the one bruce sold but from the looks of it that looks like a copy.
  8. Otto J
    Otto J
    Expand Collapse
    May 31, 2001
    7,793
    25
    Offline
    That’s not a Mopar 727 filter. It’s a General Motors 200C filter
  9. INEEDAGN
    INEEDAGN
    Expand Collapse
    Seen Your Member
    Feb 28, 2003
    3,570
    265
    Offline
    Well I'll be damned. I didn't look that close at the second pic I just knew most of those setups used the mopar filter. You appear to be correct sir.
Share This Page
