Simple question about airbags
BlackMetal
Can't find this information at any vendors. If you buy two airbags for the rear suspension, how high can they actually raise the back of your car? I'm not too concerned about the actual off-the-line performance, I just want to know if they can be used to achieve a better stance until I have the money to redo my suspension. I can't tell by the pictures how much of a difference they might make.
I would say about an inch or two. I did the same thing that you are trying to achieve. The higher the air pressure in the bags, the higher your rear end will raise. However, there obviously is a limit to how much air you can pump in which I think is around 35psi or something. It made a noticeable difference on my car leaving both bags at 15psi. :D
Alright, sounds good. I want it for the stance as well as a little reassurance when I get my 17x9.5s installed in back. Thanks.
