JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Just wondering if there is a big advantage using both (i.e. burnout with a little pool of VHT in front of slicks)? The track isn't prepared with VHT or any other traction enhancer. Any suggestions?
Tech Advisor
Staff member
Probably a better way is to use something like "Tire Bite". You brush this on your slicks. It takes a couple days cure time and maybe 2-3 coats.
Did this on an old pair of Hoosier slicks and they stuck better than any tire since.
