Sloppy Steering
TURBO2
128
0
16
cjenterprises.myamsoil.com
I have a 1986 GN and my steering is very sloppy. If the road has any contours to it, the car will follow it. I tried a suggestion to tighten up the steering box and it made no difference so I ordered a new box. With the new steering box, different rims and tires, and a front end alignment it still has made no change. The mechanic that did the work said that the rag bushing looked like new and the suspension pieces were all good. What could be causing this?
Geezy
407
43
28
37
I have the same issue on my 87.
I had to change upper and lower ball joint to tall, shocks, arms, and add a. Bumpsteer kit
Geezy
407
43
28
37
Oh and adding a thicker rear sway bar helped alot
dank GN
BlackArts Automotive (661)993-8277
Jan 11, 2009
3,521
414
83
SoCal the high desert
If you still have the rag joint in the steering shaft that causes a lot of slop
. That’s why a lot of ppl replace it with a Jeep steering shaft to eliminate that rag joint .
Top Bottom
